ProductEVO 75/150How can I play all tracks from a connected USB hard drive on my Network Player?
EVO 75/150
To enable you to play all tracks from a connected USB hard drive on your Network Player, just follow these three steps.
1. Create a folder called 'Music' at the top level (root) of your USB hard drive.
Note: If you don't use a 'Music' folder and instead have your artists as the top level (root) folders, then you'll only be able to press play on individual tracks and add them to the queue individually.
2. Move all music on your drive into this new folder.
3. Once the USB drive is connected to your player, you will have the option to play all the tracks by navigating to the 'Library' tab in the StreamMagic app > [USB Drive Name] > and pressing play on the Music folder.
