Open the Deezer app and choose the playlist, album, song, etc. that you wish to stream to your player.
Select the speaker icon within Deezer, then select 'Google Cast'. Select your player from the list.
Deezer should now be casting your chosen content to your player.
Select the speaker icon within Deezer, then select ‘AirPlay & Bluetooth’. Select your player from the list.
Deezer should now be streaming your chosen content to your player via AirPlay.
Note: Please ensure that you sign into your Deezer account when prompted to do so. This will only be required on the first instance of use to link the account to the StreamMagic app.
Open the StreamMagic app and navigate to the ‘Library’ tab, and then select Deezer.
Choose the playlist, album, song, etc. that you wish to stream to your player.
Deezer should now be streaming your chosen content to your player.
Note: *Deezer is only available within the StreamMagic app when running firmware version 129-b-004 or later and StreamMagic app version 2.9.0 or later.
