Melomania 1/1+Common issuesMelomania 1+ Pairing Guide (Android)
Melomania 1/1+
Step 1. Charge new earphones for 30 minutes before pairing.
Step 2. Take the earphones out of the charging case.
If your Melomania 1+ earphones have not previously been paired, or you have reset them, they should automatically be ready to pair. The correct state for pairing is: the LED on one earphone flashing blue and white alternately, and the other earphone’s LED flashing white. They must be in this state to pair successfully.
  1. If the LED is unlit, then the earphone is OFF. Touch the control surface for about 2 seconds until the voice prompt says ‘power on’ and the LED flashes white. Both earphones must be powered ON.
  2. If both earphones’ LEDs are flashing white, then neither of them are waiting to pair. Touch the control surface on ONE earphone, it doesn’t matter which one, for about 3 seconds until the voice prompt says ‘waiting to pair’ and the LED flashes blue and white alternately. One earphone must be waiting to pair.
Step 3. Go to phone Settings and select Connections.
Step 4. Turn ON Bluetooth if it is OFF.
Step 5. Select Bluetooth settings.
Step 6. Select the Melomania 1+ from the ‘Available devices’ list.
You will see either Melomania 1+ L or Melomania 1+ R in the ‘Available devices’ list, select this. If you have manually enabled both earphones for pairing you will see them both in the ‘Available devices’ list, this is fine, just select either one of them.
Step 7. Accept the pairing request.
Press ‘OK’.
Once accepted you will hear the “Melomania Connected” voice prompt and the LED on the selected (primary) earphone will stop flashing blue and white, and will flash white only.
Step 8. Accept pairing request from secondary earphone.
Soon after pairing the primary earphone you will see a pop-up message requesting to pair the secondary earphone, press ‘OK’. You will hear the ‘Melomania Paired’ voice prompt and the LED on the secondary earphone will flash white.
If you are connecting to a phone that supports TWS+, the secondary earphone will connect automatically. If it does not, press the earphone that is not displaying as connected.
Step 9. Your Melomania 1+ earphones are now connected.
Once both earphones are correctly paired, you will see that the primary Melomania 1+ (L in the example below) is shown as Connected for calls and audio, and the secondary earphone (R in the example below) is shown in the ‘Paired devices’ list.
If you are connecting to a phone that supports TWS+, both earphones will show battery levels in the Bluetooth settings when connected, with the bud that was selected in Step 6. Showing as ‘Active’.
Troubleshooting
If Pairing is not successful and you need to start again
  1. In the Bluetooth Settings ‘Paired devices’ list, press the gear icon next to the Melomania device.
  1. Press ‘Unpair’.
  1. Repeat to forget the other earphone.
  2. Continue with manual pairing from Step 2.
