Melomania 1/1+Common issuesHow does the Find my Earbuds feature with Melomania 1+ work?
Melomania 1/1+
The Find my Earbuds feature allows the Melomania app to use the location services of your device to record the last place they were connected to the device.
This is a benefit if you misplace your earbuds, as it will provide you with the last known location, enabling you to retrace your steps and find them.
This feature does require mobile data, so it will use part of your mobile device's data plan. Please note, we do not collect your location or usage data.
To enable this feature, you must allow the app to use your device’s location via the permission prompt that can be found by accessing the app, or by going into your device Settings, and ensuring the permission is enabled that way.
Important: You must also be Signed In to the app, this will allow you to use the feature.
Note: You will only be able to see the last time your M1+ was connected to your device. You will not be able to track the M1+ in real time.
1. Accessing Find My Earphones (with earphones connected):
Go to My Account found on the Settings tab.
2. Select My Devices.
3. Select your Melomania device.
4. Select Find My Earphones.
On Android: If you have not accepted the app’s request to use the device location, the prompt will appear here, select ‘Allow’ when prompted.
5. You will see the location of your device where you currently are, and therefore where the earphones are connected.
6. Accessing Find My Earphones (without earphones connected):
On the Earphones Not Connected page, select Find My Earphones.
7. Select your Melomania device.
8. You will see the location of your device, the last time the earphones were connected.
  • Please note that you will only be able to see the last time your M1+ was connected to your device. You will not be able to track the M1+ in real time.
Note: You will only be able to see the last time your MT was connected to your device. You will not be able to track the MT in real time.
