1.) Ensure that both of the supplied WiFi antennas have been connected to the rear of the unit, and that your AXN/MXN is in range of your wireless router. Then power on your unit.
2.) Go to the Wi-Fi settings on your iOS device and under ‘SETUP NEW AIRPLAY SPEAKER’ select 'AXN10' or 'MXN10'.
3.) Once connected, to complete unit setup download and install the StreamMagic app from the Apple App store.
Download and install the StreamMagic app from the Google Play store.
Open the StreamMagic app and select ‘Connect’.
Under Choose a device select 'Set up a new device' and then select the 'AXN10' or 'MXN10'.
Select ‘Wireless Connection’ and then 'Continue'.
Your Android device will now show all available Wi-Fi devices in range. Select 'Setup:AXN/MXN10'.
Once connected, you will be prompted to enter your Wi-Fi network password. Enter the password and select 'Continue'.
Your AXN/MXN will now connect to your Wi-Fi network, this may take up to a minute.
Once connected, complete the initial setup of your unit within the StreamMagic app.
