ProductMelomania M100Why am I seeing the pairing LED sequence on my M100 when they are already connected to my Android device?
Melomania M100
If you are seeing the pairing LED sequence while your M100s are already connected to your Android device, this may be caused by having 'LE Audio' enabled in your device settings.
If this is the case, we would suggest switching off the 'LE Audio' setting in your Android device.
