The default time for APD to be activated on the M100 is 60 minutes. The length of time that it will take for the M100 to power off when they are detected as being inactive can be adjusted within the app. Auto power down will occur after 30 minutes or 60 minutes, or it can be disabled.
You can adjust or disable APD in the Melomania Connect app by following the steps below:
Select ‘Auto Power Off’ in the app.
Choose the length of time it will take for APD to be activated or choose to disable APD.
Note: APD requires the M100 to be detected as inactive and not in use. APD will still be activated on the ear buds even if they remain connected to a device.
