Our Cambridge Audio engineers have tuned the M100 to sound great for the best audio sources. Not all sources are equal, however, and neither are our preferences for sound, so we have included a seven-band equaliser in the Melomania Connect app, which allows you to adjust the sound for your listening needs.
EQ Presets:
The M100 has the option of 6 presets:
Flat
Blues
Electronic
Natural
Rock
Voice
Customising Presets:
You can customise one of the existing presets or create your own EQ preset from scratch by following the steps below:
Under ‘Equaliser’ in the app, select ‘Customise’.
Edit an existing EQ preset or create your own preset from scratch.
Select ‘Save as new EQ preset’.
Enter a title for the custom EQ preset, then press ‘OK’.
Your custom EQ preset is now saved.
Note: You can save up to 5 custom EQ presets.
Deleting a Custom EQ Preset:
Select ‘Edit’.
Select the ‘X’ icon next to the Custom EQ preset you wish to delete.
The Custom EQ preset is now deleted.
