ProductCXN100Will the Network Player default to a wired connection when connected to a router via Ethernet?
CXN100
Yes, the unit will automatically default to a wired connection when an Ethernet cable is connected.
You can also change the desired connection manually to one of the options below via the front panel network settings:
  • Auto
  • Wired Only
  • Wi-Fi Only
