ProductCXN100Can my Network Player play USB Audio at 24-bit/192kHz?
CXN100
The Network Player can certainly play files at 24-bit/192kHz.
First, make sure that the network Player is set to USB Audio class 2.0 mode. This is done via the Audio settings menu on the front display.
Setup for PC:
Make sure to install the appropriate Cambridge Audio Windows 2.0 USB driver on your computer. Information on which driver to install can be found below. Once you have finished the installation, go to the Sound menu in Control Panel and set the Cambridge Audio USB 2.0 product as the default output device.
Setup for Mac:
If you are using a Mac you will not need to install any additional drivers. Simply navigate to System Preferences > Sound and select the CXN (V2) as the output.
For Windows users the driver you will require will depend on your operating system.
Our range of drivers can be downloaded from our Driver updates page
