Using a USB audio cable (Type A to Type B), connect the USB Audio In on your EDGE NQ to a USB port on the Mac.
Note: If using a Mac without a USB Type A port, you may also use USB Type C (Thunderbolt 3) to USB Type B connection.
If using the front panel source selector of your EDGE NQ, switch to USB Audio.
If using the StreamMagic app, go to the Home tab, then select USB Audio within the Sources section.
Select the CA Edge 2.0 as the output sound device.
Select the CA Edge 2.0 as the output sound device on the left column, and then using the drop-down options select the desired bit depth and sample rate preference.
