ProductEDGE NQHow do I connect my EDGE NQ manually using the IP address?
EDGE NQ
If you are having issues connecting your unit to your home network within the StreamMagic app, we've now added the facility to connect to a unit directly, via its IP address.
1. If unable to discover your unit automatically, press 'CONNECT'
2. Press 'here' to enter your IP address manually. If using Android, press 'ENTER IP ADDRESS'
3. Once you have entered the IP address, press 'Connect'
Please Note: If you are unsure how to locate your unit's IP address, please see this article.
4. Your unit should now be connected to the StreamMagic app
