ProductCXN (v2)Do I need to connect both of the supplied Wi-Fi antennas for the CXN100 to work?
CXN (v2)
Yes, if you are connecting your CXN100 to your network wirelessly, you will need to connect both of the supplied antennas to enable full Wi-Fi functionality and the strongest possible wireless network connection.
Bluetooth functionality will also only be possible when one of the antennas is connected to the port with the Bluetooth symbol.
