Note: No extra drivers are required when using a Mac.
Using a USB Audio cable (Type A to Type B), connect the USB Audio In on your device to a USB port on the Mac.
Note: If using a Mac without a USB Type A port, you may also use USB Type C (Thunderbolt 3) to USB Type B connection.
This can be done using the source selector on the front of the device, or by going to the Home tab and then selecting USB Audio within the Sources section of the StreamMagic app.
Select your Network Player as the output sound device.
Select the device as the output sound device on the left column, and then using the drop-down options select the desired bit depth and sample rate preference.
Note: This step is optional.
