We have had reports that some users are experiencing an issue when scanning for DAB radio stations on the AXR100D, where the unit is only able to scan and store 60 stations.
We have now developed a fix for this issue which enable users to store an unlimited number of DAB radio stations. Please follow the steps below to carry out this procedure:
Note: The required .bin file can be found as an attachment at the bottom of this article.
Copy to the root of the drive, not inside a folder, and do not rename the file.
The unit will then automatically detect the file on the USB drive and update automatically. The unit will then switch off. (If ‘No File’ message is displayed then restart at Step 1)
Procedure is complete.
