After making any connections to your unit, activate the AXA35 by pressing the Power button on the front of the unit.
1. To enter the audio menu, press either the Menu button on the front of the unit (7) or on the remote control (4)
2. Step through the available settings by pressing the Menu button
The settings available are in order Bass, Treble and Balance.
3. When you wish to make an adjustment for bass, treble or balance, simply rotate the Volume control or use the Volume control buttons on the remote control
4. To exit, wait for five seconds, until the unit returns to normal mode
