ProductAXA35Technical specifications
AXA35
Power output - 35 watts (into 8Ω)
THD (unweighted) - <0.01% @ 1kHz, 80% of rated power
Frequency response (-3dB) - 5Hz - 50kHz
S/N ratio (ref 1W) - >82dB (unweighted)
Input impedances - 47k ohms
Power Amp damping factor - >50
Max. power consumption - 260W
Bass/Treble controls - Shelving, ultimate boost/cut +/- 10dB @ 100Hz and 10kHz
Standby power consumption - <0.5W
Inputs - 4x RCA, 1x Phono, 1 x 3.5mm Aux input (front panel)
Outputs - Speakers, Rec Out, USB 5V power
Dimensions (HxWxD) - 83 x 430 x 335mm (3.3 x 16.9 x 13.2”)
Weight - 5.6kg (12.3lbs)
