Product851NTechnical specifications
851N
D/A CONVERTERS
Twin Analog Devices AD1955 24-bit DACs
DIGITAL FILTER
2nd Generation ATF2 up-sampling to 24-bit/384kHz. Linear Phase, Minimum phase or Steep modes
ANALOGUE FILTER
2-pole differential Bessel with DC servo (for both XLR and RCA outputs)
DIGITAL AUDIO INPUTS
1 x AES/EBU, 2 x S/PDIF coaxial and 2 x TOSLINK optical
USB AUDIO INPUT
USB Type B conforms to USB Audio profile 1.0 or 2.0 (user selectable)
ANALOGUE AUDIO OUTPUTS
Balanced XLR and unbalanced RCA analogue audio outputs
COMPATABILITY
UPnP: Linear PCM 16-24 bit, 11.025-192kHz Local USB media: Linear PCM 16-24 bit, 11.025-192kHz USB Audio1.0: Linear PCM 16-24 bit, 44.1-96kHz USB Audio 2.0: Linear PCM 16-24 bit, 44.1-192kHz or DSD (x64) TOSLINK 16-24 bit, 32-192kHz (using high quality TOSLINK optical cable) S/PDIF: Linear PCM 16-24 bit, 32-192kHz AES3/EBU: Linear PCM 16-24 bit, 32-192kHz BT100 Bluetooth receiver: A2DP plus aptX Internet radio: 16-24 bit, 11.025-192kHz
AUDIO FORMATS
ALAC, WAV, FLAC, AIFF, DSD (x64), WMA, MP3, MPEG-4, AAC, AAC-HE, AAC+ and OGG Vorbis
STANDBY POWER CONSUMPTION
<0.5W
DIMENSIONS
115 x 430 x 360mm (4.5 x 16.9 x 14.2")
WEIGHT
8.1 Kg (17.9lbs)
