Product851NUSB Audio: What type of USB cable should I use?
851N
You will need a USB A to USB B or a USB C to USB B cable depending on the type of USB ports available on your PC/Laptop or Mac device.
Always use a high-quality USB connection cable certified as USB Hi-Speed.
USB cable connections longer than 3m may result in inconsistent audio performance.
