Our range of drivers can be downloaded from our Driver updates page
The USB driver is required to ensure ASIO is installed, as this allows music player apps to have exclusive use of the peripheral, in addition to enable native DSD support.
This will show any connected Cambridge Audio USB Audio device.
You should notice that the EDGE A appears as 'CA USB Audio' within the playback section of your computer's Sound Settings (Control Panel > Sound > Playback).
Windows Playback devices
Once completed the EDGE A should also appear in the CA Control Panel.
EDGE A listed as a USB Audio Device within CA Control Panel.
Here navigate to Advanced where you can select the sample rate and bit depth to be used. We would recommend selecting the highest available. (This step is optional.)
EDGE A Advanced speaker properties
CA Control Panel showing selected Sample Rate.
