The TVB2 soundbar can be placed on a flat surface in front of or under your TV or can be wall mounted with the included bracket and bolts.
The subwoofer can be placed anywhere in the room, up to a maximum of 10 metres away from the bar.
The subwoofer connects to the soundbar via Bluetooth, so can be positioned out of view if desired.
Please note: Bluetooth signal interference can sometimes occur within a room where other radio signals are being used, such as:
Routers
Microwave ovens
Other wireless speakers
Cordless telephones
The strength and reliability of any wireless signal can be affected by potential sources of interference.
If the soundbar and subwoofer are unable to pair, the message “NO SUB” will appear on the soundbar. If this occurs, disconnect the subwoofer and soundbar from mains power before moving the units closer together and then attempt the connection once more.
