ProductMinx S325How do I connect a second subwoofer?
Minx S325
If you wish to connect a second subwoofer to your setup, this can be done using the line out connections on the rear of your Minx X301. Connect the line out of your X301 to the line in of a secondary subwoofer and adjust the controls accordingly to achieve your desired sound.
connecting a second subwoofer
