You can assign up to 99 of your favourite Internet Radio stations to presets on your player, which can then be recalled using the StreamMagic app or remote control (programmable buttons 1-4).
Within the StreamMagic app navigate to the Radio tab.
Use the Search for Radio search tab at the top of the page or enter a Custom URL link by selecting URL.
Note: Please ensure that the custom URL stream is one of the following supported file types: ALAC, WAV, FLAC, AIFF, DSF and DFF containing DSD64 at 2.8224 MHz or DSD128 at 5.6448 MHz, WMA, MP3, AAC, HE AAC, AAC+ and OGG Vorbis.
3.
Once you have located the station you wish to store, select and you will be prompted with the option to Play now or Add to presets.
4.
Add station to the desired preset for your player between 1-99.
5.
You will then receive confirmation that the station is saved to the chosen preset.
Within the StreamMagic app navigate to the Home tab.
Scroll to the bottom of the page where you find your players Presets, and select EDIT.
3.
To remove station from preset, tap the icon and then press Delete.
