The USB Audio Input on your player is designed for use with PC. When connected, you will be able to playback music to the network player directly from the computer’s apps, software or media players.
Using a USB audio cable (Type A to Type B), connect the USB Audio In on your EDGE NQ to a USB port on the PC.
If using the front panel source selector of your EDGE NQ, switch to USB Audio.
If using the StreamMagic app, go to the Home tab, then select USB Audio within the Sources section.
This will show any connected Cambridge Audio USB Audio device and current sample rate.
Select the Edge NQ as your output device from the drop-down menu. This will appear as 'CA Edge Range’.
Once selected, select Apply, then OK.
