Here at Cambridge Audio, we’ve been working hard to make your Edge NQ experience even better! There is a new firmware update.
The next time you switch on your Edge NQ it will automatically see that an update is available and will prompt you to update. Alternatively, you can update your device manually by going to Settings within the StreamMagic app.
Please Note: Edge NQ users with preamp mode switched off will need to re-apply this setting after the update.
20th January 2023
General release 022-a-132 is now available.
Fixed a crash when browsing the Media Library via the front panel
18th January 2023
General release 022-a-131 is now available:
Added Deezer support via the Airable service
Updated TIDAL and Qobuz integrations for support via the Airable service
Fixed an issue with Qobuz playlists
Updated Spotify
Fixed a crash when starting Audirvana playback
Updated Italian language translations
Known issues:
Some translations are missing or incomplete
Some translations feature symbols instead of letters
Track resolution is missing from Qobuz
Deezer symbol is displayed when listening to Qobuz
We are working on a fix for all of these known issues as a priority and will release an update to address them as soon as we can. We apologize for any inconvenience caused.
Notes:
Please make sure you have also updated to the latest version of the StreamMagic app version 2.10.0 in order to take advantage of some of these features.
If you have saved any TIDAL or Qobuz presets within the StreamMagic app you may need to save these again after updating.
19th April 2022
General Release 022-a-124 is now available.
Updated Cast.
Fixed Casting BBC Sounds.
Fixed Casting Deezer.
Fixed Casting YouTube Sounds.
