ProductEDGE NQHow can I stop the Edge NQ powering down when not in use?
EDGE NQ
Your Edge NQ will power off after approximately 20 minutes of inactivity. This feature is called Auto Power Down or APD. This can be adjusted to power down (in 5-minute increments) between 5 minutes and 2 hours.
If you want your unit to remain switched on until you manually power it off, this feature can also be disabled.
If you wish to adjust this setting; simply navigate to the settings menu in the StreamMagic app and adjust the Auto Power Down and set your preferred option.
