Both the EVO 75 and EVO 150 are Roon Ready Certified (out of the box) and should be
recognised as such by your Roon installation.
Before you can use the EVO as a Roon endpoint, you must enable it in the Audio section of
the Roon Settings Menu - just click on the purple enable button and you are ready to play!
Ensure the EVO is connected to the same network as your Roon Core and it is switched
on.
1. Open Roon on your preferred device
2. Tap or select settings in the sidebar, scroll down and select Audio
3. Your Evo will be grouped with other Roon Ready devices in your system
4. Select or Tap the Enable button
Your Evo is now available as a Zone in Roon and can be selected from the Zone list
which pops up when you tap/click on (Select a Zone) or when you tap on the current
Zone icon on the bottom left (portrait mode on mobile devices) or bottom right
(landscape mode).
For playback of normal compressed and uncompressed music formats (FLAC, MP3,
WAV, AIFF etc) no further action is necessary.
If you will be listening to Hi-resolution audio files with MQA encoding, more configuration
may be necessary - please see our FAQ ‘How to playback MQA encoded files using
EVO’ for more information.
