26th July 2023
General release 132-b-007 is now available for Evo 75/150.
Improved network connectivity when switching between multiple access point on mesh networks
Improved playback states when skipping multiple tracks
Disabled Spotify Normalisation
Display Qobuz logo when playing Airable tracks via the media library
Fixed a crash when selecting UPnP track presets after firmware upgrade
Show the Bluetooth source device name on the "Now Playing" screen
Fixed the language select screen when connecting to the network via Ethernet after power-on during setup
Display multiple artist names on the front panel when playing Spotify via AirPlay
26th April 2023
General release v132-b-004 is now available for Evo 75/150:
Improved digital input sample rate and signal status reporting.
Fixed a crash when initiating network setup mode via the front panel info screen following a factory reset.
Fixed low sample rate playback (22kHz) on the digital inputs.
Added new start-up screen animations.
27th March 2023
General release v131-b-003 is now available for Evo 75/150:
Fixed ARC no audio output when switching to ARC input via TV power on commands.
Fixed webmin "Restart" icon visibility when viewing the webmin settings page in Dark Mode.
Fixed French language webmin settings page translations.
Updated Polish translations.
Added new translations for various untranslated strings.
Improved Cast and Roon multi-room playback sync.
18th January 2023
General release v131-b-001 is now available for Evo 75/150:
Updated TIDAL and Qobuz integrations for support via the Airable service
Fixed an issue with Qobuz playlists
Updated Qobuz front panel logo
Updated Spotify
Added restart button to the webmin settings page
Updated translations
Known issues
Some translations are missing or incomplete
Some translations feature symbols instead of letters
Track resolution is missing from Qobuz
Deezer symbol is displayed when listening to Qobuz
We are working on a fix for all of these known issues as a priority and will release an update to address them as soon as we can. We apologize for any inconvenience caused.
Important Notes:
Please make sure you have also updated to the latest version of the StreamMagic app version 2.10.0 (iOS) or 2.10.1 (Android) in order to take advantage of some of these features.
If you have saved any TIDAL or Qobuz presets within the StreamMagic app you may need to save these again after updating.
3rd November 2022
General Release 130-b-002 is now available for Evo 75/150
Updated Spotify
Improved Deezer metadata handling
Fixed no audio output after firmware update when Tone Control is enabled
Fixed occasional Airplay audio anomalies at the start of tracks when skipping through playlists and albums
15th September 2022
General Release 129-b-004 is now available for Evo 75/150
Added Deezer streaming services
Improved unit behaviour when performing a factory reset in network standby mode
Audirvana improvements.
27th June 2022
General Release 128-b-004 is now available for EVO 75 and EVO 150
Fix for a rare screen start-up issue.
30th March 2022
General Release 127-b-001 is now available for Evo 75/150
Fixed Chromecast disconnects.
Updated TIDAL Connect.
Updated MQA library.
Fixed lock-up when powering off Evo during splash screen start up.
Fixed previous streaming info briefly displayed on the front panel when entering network standby.
Improvements for screen issues.
Updated Roon icons.
17th February 2022
General Release 126-b-001 is now available for Evo 75/150
Updated Spotify
Fixed crash when using Roon DSP sample rate conversion
Fixed AirPlay disconnects
Fixed AirPlay sample rate/bit depth not being displayed
Display name of sending device on AirPlay source
Fixed long delay before playing Antenne Bayern stations
Fixed a crash when playing RNE clasica radio station
Fixed info screen fields for Network & Internet not updating when language changes
Added Italian translation for "Media Library"
12th January 2022
General Release 125-b-002 is now available for Evo 75/150
Added exFAT USB drive support
Updated AirPlay
Improved Russian and Polish front panel info display page
Improved front panel info display page spacing
Fixed volume level returns to 1 after Eco mode power cycle
Fixed distortion when attempting to play unsupported native DSD512 steams via USB Audio
Fixed volume levels when enabling unsupported Tone Control during DSD (DoP) playback
Fixed Left/Right output swapped when playing DSD files
Fixed a loud pop when switching from a home theatre bypass enabled analogue input, to a non-home theatre bypass enabled analogue input with an active signal
20th October 2021
General Release 124-d-005 is now available for Evo 75/150.
Fixed a unit crash when adding tracks to the queue
Fixed broken PBB internet radio streams
Fixed reconnecting to the network when Wi-Fi signal is lost temporarily
Fixed a short burst of sound when entering Eco mode standby while listening to physical inputs
Updated Japanese translations
Fixed info screen translations
Updated patch to improve UI crash
Updated the info screen to return to the current source after one minute of inactivity
Updated Cast.
23rd September 2021
General Release 124-c-001 is now available for Evo 75/150:
Updated Cast
Fixed low sample rate internet radio playback
Fixed WMA file meta-data parsing
Fixed entering Network Standby during Bubble UPnP queue playback
Fixed mute state after switching between speaker and wired headphone outputs
Patch to improve UI crash
18th August 2021
General Release 124-b-001 is now available for Evo 75/150:
Fixed start of track cut-off when starting Spotify playback from Network Standby
Fixed adjusting the display brightness when the unit is in Network Standby mode
Fixed audio issues when playing low sample rate streams via digital inputs
Fixed a crash when quickly skipping through tracks in the queue using the IR remote control
Fixed distortion when using both Tone Control and Input Trim at the same time on analogue inputs
Fixed incorrect DSD format metadata reporting on some hardware revisions
16th July 2021
General Release 124-a-087 is now available for Evo 75/150:
Don't set back-light when the level is changed when in standby
Update German translations for Bright and Dim
Fix re-enabling IR remote control after adjusting the volume via ARC
12th July 2021
General Release 124-a 084 is now available for Evo 75/150:
Various crash fixes.
Improved Tone Control response on analogue inputs
Updated the Cambridge Audio logo on the webmin settings page
Fixed discrepancies in volume when setting the volume via the front panel and TV ARC
Fixed low-resolution radio station playback
Prevent the volume level being displayed when powering on from network standby
Updated home theatre bypass and tone control translations
Updated description for "Moving Magnet Phono"
Updated USB Audio descriptions and translations
Fixed random TIDAL pauses
Restart the whole UI if rebooted while in network standby (fix corrupted screen)
Fixed crashes during prolonged Qobuz playback via Cast
Fixed missing Bluetooth input setup prompt
Fixed Bluetooth output when the analogue input signal is low
Fixed front panel lock-ups
Added input trim
1st June 2021
Evo General Release 124-a-018 is now available for Evo 150/75:
Added Tone Control.
Updated network status icons.
Improved network setup mode via the front panel.
Fixed IR remote control functions when Bluetooth output is selected.
Fixed brief audio drop-outs when re-selecting the current Bluetooth output.
Improved progress bar reporting when skipping tracks.
Fixed Bluetooth volume problem if set to 0 before pairing.
Increased maximum number of presets from 20 to 99.
Fixed metadata reporting for Control4/RTI systems.
Fixed volume level discrepancies when setting the volume via the StreamMagic App, front panel or TV ARC control.
Fix to prevent the unit from powering off if the remote control power button is held during power on from ECO Mode standby.
MQA performance improvements.
28th April 2021
Evo General Release 122-a-207 is now available for Evo 150/75:
Updated TIDAL Connect to version 1.1.7.5.
Fixed audio drop-outs at the start of MQA tracks via TIDAL Connect
Fixed audio drop-outs when pausing and resuming MQA playback via TIDAL Connect
Improved stability when switching between MQA sample rates and sources.
Changed "play-from-here" behaviour to clear the current queue before adding new tracks
Updated the Roon Ready on-device logo
Fixed selecting sources if the current source has been disabled
Fixed unwanted user interface artefacts when switching between French and Dutch languages
Fixed unwanted user interface artefacts when selecting output devices with unusually long names.
The source list no longer wraps around
