Please Note: Home Theatre Bypass is only available for EVO 75 and EVO 150, and only for use with an AV receiver.
Enabling Home Theatre Bypass will ensure that the selected source outputs line-level volume, delegating volume control to your home theatre system.
IMPORTANT: Before confirming, please be aware enabling Home Theatre Bypass will set the source volume to full and functionality of volume will be disabled. Therefore, ensure the volume of the AV receiver is set to a low volume first, and then adjust accordingly once enabled.
