ProductEVO 75/150What is in Early Update for EVO 75 and EVO 150?
EVO 75/150
23rd February 2023
Early Update 131-b-003 is now available for Evo 75/150.
  • Fixed ARC no audio output when switching to ARC input via TV power on commands.
  • Fixed webmin "Restart" icon visibility when viewing the webmin settings page in Dark Mode.
  • Fixed French language webmin settings page translations.
  • Updated Polish translations.
  • Added new translations for various untranslated strings.
  • Improved Cast and Roon multi-room playback sync.
28th October 2022
Early Update 130-b-002 is now available for Evo 75/150.
  • Updated Spotify
  • Improved Deezer metadata handling
  • Fixed no audio output after firmware update when Tone Control is enabled
  • Fixed occasional Airplay audio anomalies at the start of tracks when skipping through playlists and albums.
22nd August 2022
Early Update 129-b-002 is now available for Evo 75/150
  • Audirvana improvements.
12th August 2022
Early Update 128-b-005 is now available for Evo 75/150
  • Improved unit behaviour when performing a factory reset in network standby mode.
8th June 2022
Early Update 128-b-004 is now available for Evo 75/150
  • Improvements for screen issues.
10th May 2022
Early Update 128-b-002 is now available for Evo 75/150
27th April 2022
Early update 128-b-001 is now available for Evo 75/150
23rd March 2022
Early Update 127-b-001 is now available for Evo 75/150
  • Fixed Chromecast disconnects
  • Updated TIDAL Connect
  • Updated MQA library
  • Fixed lock-up when powering off Evo during splash screen startup
  • Fixed previous streaming info briefly displayed on the front panel when entering network standby
  • Updated Roon icons.
9th February 2022
Early Update 126-b-001 is now available for Evo 75/150
  • Updated Spotify
  • Fixed crash when using Roon DSP sample rate conversion
  • Fixed AirPlay disconnects
  • Fixed AirPlay sample rate/bit depth not being displayed
  • Display name of sending device on AirPlay source
  • Fixed long delay before playing Antenne Bayern stations
  • Fixed crash when playing RNE clasica radio station
  • Fixed info screen fields for Network & Internet not updating when language changes
  • Added Italian translation for "Media Library"
16th December 2021
Early Update 125-b-001 is now available for Evo 75/150
  • Added exFAT USB drive support
  • Updated AirPlay
  • Improved Russian and Polish front panel info display page
  • Improved front panel info display page spacing
  • Fixed volume level returns to 1 after Eco mode power cycle
  • Fixed distortion when attempting to play unsupported native DSD512 steams via USB Audio
  • Fixed volume levels when enabling unsupported Tone Control during DSD (DoP) playback
  • Fixed Left/Right output swapped when playing DSD files
  • Fixed a loud pop when switching from a home theatre bypass enabled analogue input, to a non-home theatre bypass enabled analogue input with an active signal.
13th October 2021
Early update 124-d-005 is now available for Evo 75/100
  • Fixed a unit crash when adding tracks to the queue
  • Fixed broken PBB internet radio streams
  • Fixed reconnecting to the network when Wi-Fi signal is lost temporarily
  • Fixed a short burst of sound when entering Eco mode standby while listening to physical inputs
  • Updated Japanese translations
  • Fixed info screen translations
  • Updated patch to improve UI crash
  • Updated the info screen to return to the current source after one minute of inactivity
  • Updated Cast
16th September 2021
Early update 124-c-001 is now available for Evo 75/100
  • Updated Cast
  • Fixed low sample rate internet radio playback
  • Fixed WMA file meta-data parsing
  • Fixed entering Network Standby during Bubble UPnP queue playback
  • Fixed mute state after switching between speaker and wired headphone outputs
  • Patch to improve UI crash.
12th August 2021
Early Update 124-b-001 is now available for Evo 75/150
  • Fixed start of track cut-off when starting Spotify playback from Network Standby.
  • Fixed adjusting the display brightness when the unit is in Network Standby mode.
  • Fixed audio issues when playing low sample rate streams via digital inputs.
  • Fixed a crash when quickly skipping through tracks in the queue using the IR remote control.
  • Fixed distortion when using both Tone Control and Input Trim at the same time on analogue inputs.
  • Fixed incorrect DSD format metadata reporting on some hardware revisions.
5th July 2021
Early Update 124-a-078 is now available for Evo 75/150
  • Fixed info screen translations.
  • Updated description for "Moving Magnet Phono"
  • Updated USB Audio descriptions and translations
  • Updated to TIDAL Connect SDK 1.1.9.13.
  • Restart the whole UI if rebooted while in network standby (fix corrupted screen).
  • Fixed crashes during prolonged Qobuz playback via Cast.
17th June 2021
Early update 124-a-037 is now available for Evo 75/150
  • Various crash fixes
  • Improved Tone Control response on analogue inputs
  • Updated the Cambridge Audio logo on the webmin settings page
  • Improved mute/un-mute
  • Fixed low-resolution radio station playback.
  • Prevent the volume level being displayed when powering on from network standby.
27th May 2021
Early Update 124-a-018 is now available for Evo 75/150
  • Added Tone Control.
  • Updated network status icons
  • Improved network setup mode via the front panel
  • Fixed IR remote control functions when Bluetooth output is selected
  • Fixed brief audio drop-outs when re-selecting the current Bluetooth output
  • Improved progress bar reporting when skipping tracks
  • Fixed Bluetooth volume problem if set to 0 before pairing
  • Increased maximum number of presets from 20 to 99
  • Fixed metadata reporting for Control4/RTI systems
  • Fixed volume level discrepancies when setting the volume via the StreamMagic App, front panel or TV ARC control
  • Fix to prevent the unit from powering off if the remote control power button is held during power-on from ECO Mode standby
