Turntable Type:
Belt Drive.
Turntable Speeds:
33 1/3, 45 RPM.
Wow and Flutter:
<0.12%
Platter Material:
Aluminium die-casting.
Platter Diameter:
305mm.
Type:
Static balanced tonearm with removable headshell.
Effective Length:
221.5mm.
Overhang:
19mm.
Effective Mass:
19.8g.
Gain @ 1kHz:
42dB.
Nominal Output (supplied cartridge):
250m Vrms.
Equivalent Input Noise (A weighted):
0.1u Vrms.
RIAA Curve Accuracy:
+/-0.3dB 30Hz-20kHz.
Signal/Noise Ratio (Ref 1V OUT, 20-20K BW):
90dB.
THD+N 1kHZ:
0.0025%.
Input Impedance:
47kΩ.
Input Capcitance:
330pF.
Audio Ouput:
RCA phono/line level (switchable).
Bluetooth:
SBC/aptX/aptX HD.
Power Supply:
DC 12V.
Power Consumption:
10W max, <0.3W (Standby).
Dimensions ( W x H x D):
435 x 139 x 366.7 mm.
Weight:
9 kg.
Type:
Moving magnet cartridge.
Frequency Response:
+/- 0.5dB 30Hz-20kHz.
Stylus:
Elliptical.
Cantilever:
Alloy tube.
Output Level:
1.8~3.6mV @ 1kHz.
Recommended Tracking Force:
2g.
Recommended Load:
47kΩ.
