ProductAXR85/100How do I use FM/AM mode?
AXR85/100
Select the Tuner source using the FM/AM button on the front of the unit, or directly by pressing the FM or AM buttons on the remote.
Repeatedly pressing the FM/AM button on the front of the unit switches between FM and AM modes.
Note: For ease of tuning on first time use, we recommend that you set the AXR100D to ‘Auto’ mode. Press the Mode/Store button on the front of the unit. This button cycles through Preset, Auto and Manual modes.
When Auto mode has been selected, press the reverse ‘Skip/Scan’ button to scroll down through the station frequencies or press the forward ‘Skip/Scan’ button to scroll up through the station frequencies.
The tuner will stop at the first strong signal it finds. To move to another station press the reverse or forward ‘Skip/Scan’ button again.
