Switch the ‘output level switch’ to ‘phono’.
Connect a ground lead to the ground connection screw on the Alva TT V2, and the equipment that it is being connected to.
3.
Using high-quality RCA interconnects, connect the audio output of the Alva TT V2 to the phono input of your external phono-stage, or amplifier.
Note: Do not connect to a line-level input with the turntable set to output at phono-level.
Note: Your external phono-stage, or phono input on your amplifier MUST be suitable for use with moving coil (MC) cartridges.
