Bluetooth LED Status
Fast flashing – In pairing mode.
Slow flashing – Searching for the last paired device.
Solid – Paired to a device.
Long solid intervals – Paired to a device using aptX/aptX HD codec.
The turntable will automatically pair to your Bluetooth device.
Note: By default, the Bluetooth will attempt to connect to the last paired device every time the unit is turned on.
