Maximum Power Consumption:
10W.
Standby Consumption:
<0.5W.
Mains Inlet Voltage:
100-240V AC.
Gain @ 1kHz:
39Db.
Nominal Output:
300mV.
Sensitivity for Nominal Output:
3.35mV
Equivalent Input Noise (A-Weighted):
~0.09uV
RIAA Curve Accuracy:
+/- 0.65dB 30Hz-20kHz.
Signal to Noise Ratio Grounded Inputs ref. 1V Output (20Hz – 20kHz BW).
90dB.
THD+N 1kHz (20Hz – 20kHz BW):
<0.0025%.
Input Impedance:
47k Ohm.
Input Capacitance:
100pF.
Overload Margin:
30dB.
Crosstalk @ 20kHz:
85dB.
Subsonic Filter Characteristics:
-3dB @ 15Hz 12dB/octave.
Dimensions (H x W x D):
48 x 176 x 132 mm (1.9 x 6.9 x 5.2 “).
Weight:
0.68kg (1.5lbs).
