ProductCXN (v2)Can I use another manufacturer's remote control to operate my Network Player?
CXN (v2)
Unfortunately, this is not possible as there is no cross-compatibility with other manufacturer's remotes controls and Cambridge Audio units.
Your Network Player can be used with its own remote control (if it comes with one). Sometimes other remotes in the same range will also have some functionality compatibility with their remote. You should consult your
