Important note: Do not plug/unplug the wireless dongle when the unit is on.
Once you have done the above, power on the CXN (V2).
Alternatively (or if using Android), when prompted on the front panel display connect the CXN (V2) to the Wi-Fi network of your choice. Select your Wi-Fi network from the list and then enter your password.
Note: Wi-Fi network passwords are case sensitive.
