Press the Bluetooth/Phono button on the front panel or the Bluetooth button on the remote. "PAIRING" will show in the display.
Consult the instructions of the Bluetooth device to connect to AXR100D. When successfully connected the display will show your device name.
Note: To add another Bluetooth device, Press and hold the Bluetooth/Phono button to disconnect the current connection and repeat step 2.
The AXR100D will store up to 8 paired Bluetooth devices.
