Radio stations can be accessed via the StreamMagic app. You will be able to play radio stations on your AXN/MXN by following the steps below:
Open the StreamMagic app on your device and select the ‘Radio’ tab.
Select or search for your desired radio station, and then select ‘Play now’.
Note: Alternatively, you can select the 'URL' option and type in a radio station's URL.
Your chosen radio station should now be streaming to the AXN/MXN.
