ProductAXN10/MXN10Do I need to connect both Antennas for the AXN10/MXN10 to work?
AXN10/MXN10
Yes, if you are connecting your AXN/MXN to your network wirelessly, you will need to connect
both of the supplied antennas to enable full Wi-Fi functionality and the strongest possible
wireless network connection.
Bluetooth functionality will also only be possible when one of the antennas is connected to the port with the Bluetooth symbol.
