ProductAlva TT (v1)How do I clean and maintain my Alva TT?
Alva TT (v1)
Your record player requires little or no regular maintenance. However, if your player gathers any dust use a slightly damp anti-static cloth to remove it. Never use a dry cloth, as this creates static electricity which will attract more dust.
Please note: Fit the stylus guard before cleaning or maintenance is carried out to avoid damage.
