ProductAlva TT (v1)What's the best way to connect the Alva TT to my Amplifier?
Alva TT (v1)
You can connect the Alva TT directly to your integrated amplifier or pre-amplifier via the analogue outputs using RCA cables to an unbalanced analogue input on your amp/pre-amp.
See the diagram below:
Please note: As the Alva TT contains a phono stage built-in, do not connect the turntable to the phono input of an amplifier or use an external phono stage.
