The CXA61/81 do not feature a dedicated Phono Pre Amp Input. Some modern Turntables come with a built-in Phono Preamp stage. With this enabled you can connect directly to any available analogue RCA input. Alternatively, a separate Phono Pre-Amp such as our ALVA SoloMoving Magnet Phono Preamplifier or ALVA Duo
Moving Coil & Moving Magnet Phono Preamp would be required.
