It is also advisable to check the specifications of your speakers to ensure that they are compatible with the CXA61/81. Both amplifiers can be used with speakers with an impedance of between 4 and 8 Ohms.
The CXA61 outputs 60W RMS into 8 Ohms and 90W RMS into 4 Ohms, while the CXA81 outputs 80W RMS into 8 Ohms, 120W RMS into 4 Ohms.
If your connected speakers fall outside of these specifications, then this could also be a reason for CAP5 protection being activated, as this can cause the amplifier to be driven too hard.
