ProductEDGE AHow do I perform a factory reset?
EDGE A
A factory reset can be performed to restore the EDGE A to its original factory settings.
Press and hold the power button on the front of the EDGE A whilst plugging the power cable into the unit.
When the A1 input LED starts flashing, disconnect the power cable again to complete the factory reset.
factory reset
