ProductEDGE AHow do I connect with bluetooth?
EDGE A
To begin streaming high quality music from your chosen media source, it will first need to be paired with the Edge A.
Notes:
Your device can only be paired and connected to the Edge A while the Bluetooth source is selected.
bluetooth source
The EDGE A is always in discoverable mode when there is no Bluetooth connection. Discoverable mode means that the EDGE A is able to be paired to another Bluetooth device.
3.
The supplied Bluetooth antenna must be inserted into the rear of the unit to enable Bluetooth functionality.
bluetooth antenna
