Continuous power output:
100W RMS into 8 Ohms
200W RMS into 4 Ohms
THD (unweighted):
<0.002% 1kHz at rated power (8 Ohms)
<0.02% 20Hz – 20kHz at rated power (8 Ohms)
Frequency response: <3Hz – >80kHz +/-1dB
S/N ratio (ref full power): >103 dB
Crosstalk @ 1kHz: < -100dB
Input sensitivity: Input A1-A2 (unbalanced) 380mV RMS
Input impedances:
Input A3 (balanced) 47k Ohm
Input A1-A2 (unbalanced) 47k Ohm
Inputs: Balanced, Coax SPDIF, TOSLINK, USB Audio, Unbalanced, Bluetooth, Audio Return Channel (ARC)
Outputs: Speakers, Preamplifier, Headphones (impedance of between 8 and 600 ohms are recommended)
USB audio input: USB Audio Class 2.0 supporting up to 32-bit 384kHz PCM, or up to DSD256
Bluetooth: 4.1 (Smart/BLE enabled) A2DP/AVRCP supporting formats up to aptX HD
TOSLINK input: 16/24 bits, 32-96kHz
Coax SPDIF input: 16/24 bits, 32-192kHz
Max power consumption: 1000W
Standby power consumption: <0.5W
Dimensions: 150 x 460 x 405mm (5.9 x 18.1 x 15.9")
Weight: 24.4kg (53.7lbs
