ProductEDGE W How do I use analogue outputs with the EDGE W?
EDGE W
The output connections remain active at all times which means there are a few uses for these connections that can enable you to get even more from your system.
Any component or device connected to the EDGE W's outputs will follow the volume commands of the preamplifier, to ensure the volume increases/decreases in sync.
