ProductEDGE W Where can I find my serial number?
EDGE W
The serial numbers for most Cambridge Audio Hi-Fi products can be found on the rear of the unit, above the barcode. All recent Hi-Fi products will have the serial number written in the following format; XX X12345 1234 1234, and should be inputted as such when completing support forms or RMA requests.
Note: If you are unsure or can not find the serial number for your device, please enter a generic serial number such as XX X12345 1234 1234.
The serial number of your Melomania product is located on the bottom of the product box above the barcode. It is a 16 digit code which begins with the letters VM, AK or HA.
For example: VM C11163 7060 0000.
The serial number for the Melomania 1 and 1+ can also be located on the inside of the charging case lid.
It is a 16 digit code which begins with the letters AK.
For example; AK C12345 1234 1234.
The serial number for the Melomania M100 can also be located on the bottom of the charging case.
It is a 16 digit code which begins with the letters HA.
For example; HA C11253 1234 1234.
The serial number should be inputted in this format when completing support forms or RMA requests.
Note: If you are unsure or can not find the serial number for your device, please enter a generic serial number, such as AK C12345 1234 1234.
