Continuous power output:
100W RMS into 8 Ohms
200W RMS into 4 Ohms
THD (unweighted):
<0.002% 1kHz at rated power (8 Ohms)
<0.02% 20Hz – 20kHz at rated power (8 Ohms)
Frequency Response: <3Hz – >80kHz +/-1dB
S/N ratio (ref 1W into 8 Ohm): >93 dB
**Crosstalk @ 1kHz: < -100dB
S/N ratio (ref full power):** >113 dB
Input sensitivity: Input A1-A2 (unbalanced) 1.09V RMS.
Input impedances:
Input A3 (balanced) 47k Ohm Input
A1-A2 (unbalanced) 47k Ohm
Inputs: Balanced, Unbalanced
Outputs: Speakers, Loop out
Max power consumption: 1000W
Standby power consumption: <0.5W
Dimensions: 150 x 460 x 405mm (5.9 x 18.1 x 15.9")
Weight: 23.6kg (51.9lbs)
